Overview
GEM supports creating access policies that can span multiple instances. Doing so enables viewers in Grafana Enterprise to view data coming from more than one instance simultaneously. For example, if there were an instance called team-engineering and an instance called team-finance, an administrator might want to query metrics from both instances simultaneously.
Prerequisites
A configured Grafana Enterprise Metrics cluster. To create a GEM cluster, refer to Set up GEM.
This guide will assume there are two instances:
team-engineeringandteam-finance. To create an instance, refer to Set up a GEM Instance.
Set up an access policy with instance federation and a token
To allow queries to span both GEM instances, which are for demonstration purposes named team-engineering and team-finance, create a new access policy called leadership.
team-finance, create a new access policy called leadership. The necessary
steps are:
Create a new access policy
leadership.Enable the
Readscope.Add the instances
team-engineeringandteam-finance.Create a new token for the access-policy and store the token in your clipboard:
Set up a Grafana data source using the access policy
Create a new Prometheus data source from the Grafana configuration menu
Enter the URL of your GEM cluster, ie:
http://metrics-enterprise/prometheusFrom the Auth section, enable “Basic auth”
In the
Userfield, enter:team-engineering|team-financewhere all the instance names you wish to query across are separated by the|pipe character.In the
Passwordfield, paste the token created in the token creation process.
Queries performed using this data source in either Explore or inside of
dashboards will be performed across all the instances specified in the User
field, and are processed as if all the data was in a single instance.
