Monitor GEM usage by access policy and token
Monitor usage based on access policy and token to gain insight into which users in a tenant are running expensive queries in GEM. GEM reports these usage details in the query-frontend component’s query stats log.
Set up usage details logging
Note
If you are deploying GEM using the mimir-distributed Helm chart version 5.5 or later, usage details are logged by default.
Set up usage details logging to capture a user’s access policy and token when they run a query in GEM.
Use the following CLI flags to send request headers containing a query author’s corresponding access policy and token to the downstream query services:
header_x_access_policy_name: The query author’s access policyheader_x_token_name: The query author’s token
Use the
query-frontend.log-query-request-headerssetting in the configuration file to capture this information in the query stats log.
View usage details
To view the log for a GEM query, run the following LogQL query:
{namespace="_`<NAMESPACE>`_", cluster="_`<CLUSTER>`_", container="query-frontend"}
|= `query stats`The returned log file includes the header_x_access_policy_name and header_x_token_name headers.
You can use this information to run additional queries that aggregate the usage statistics for a specified access policy or token. For example, the following LogQL query measures the time that queries spent in-queue based on the query author’s token:
avg by (header_x_token_name) (
avg_over_time(
|= `query stats`
| logfmt
| unwrap queue_time_seconds [$__auto]
