This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana/v7.5/panels/visualizations/stat-panel.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana/v7.5/panels/visualizations/stat-panel/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Stat panel
The Stat panel shows a one large stat value with an optional graph sparkline. You can control the background or value color using thresholds.
Note: This panel replaces the Singlestat panel, which was deprecated in Grafana 7.0.
By default, the Stat panel displays one of the following:
- Just the value for a single series or field.
- Both the value and name for multiple series or fields.
You can use the Text mode to control whether the text is displayed or not.
Example screenshot:
Data and field options
Stat visualizations allow you to apply:
Automatic layout adjustment
The panel automatically adjusts the layout depending on available width and height in the dashboard. It automatically hides the graph (sparkline) if the panel becomes too small.
Display options
Use the following options to refine your visualization:
- Show - Choose how Grafana displays your data.
- Calculate - Show a calculated value based on all rows.
- Calculation - Select a calculation to apply. For information about available calculations, refer to the Calculation list.
- All values - Show a separate stat for every row.
- Limit - The maximum number of rows to display.
- Fields - Select a field name or field type (including All fields or Numeric fields) to include in this panel.
- Value - Select a reducer function that Grafana will use to reduce many fields to a single value. Click the Value list to see functions and brief descriptions.
- Orientation - Choose a stacking direction.
- Auto - Grafana selects what it thinks is the best orientation.
- Horizontal - Bars stretch horizontally, left to right.
- Vertical - Bars stretch vertically, top to bottom.
- Text mode - (Only available in Grafana 7.1+.) You can use the Text mode option to control what text the panel renders. If the value is not important, only the name and color is, then change the Text mode to Name. The value will still be used to determine color and is displayed in a tooltip.
- Auto - If the data contains multiple series or fields, show both name and value.
- Value - Show only value, never name. Name is displayed in the hover tooltip instead.
- Value and name - Always show value and name.
- Name - Show name instead of value. Value is displayed in the hover tooltip.
- None - Show nothing (empty). Name and value are displayed in the hover tooltip.
- Color mode
- Value - Colors only the value and graph area.
- Background - Colors the background as well.
- Graph mode
- None - Hides the graph and only shows the value.
- Area - Shows the area graph below the value. This requires that your query returns a time column.
- Alignment mode - Choose an alignment mode.
- Auto - If only a single value is shown (no repeat), then the value is centered. If multiple series or rows are shown, then the value is left-aligned.
- Center - Stat value is centered.
Was this page helpful?
