This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana/v8.4/panels/library-panels/add-library-panel.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana/v8.4/panels/library-panels/add-library-panel/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Add a Grafana library panel to a dashboard
Add a Grafana library panel to a dashboard when you want to provide visualizations to other dashboard users.
Before you begin
To add a library panel to a dashboard:
Hover over the + option on the left menu, then select Create from the drop-down options.
The Add panel dialog opens.
![Screenshot of the edit panel Screenshot of the edit panel]()
Screenshot of the edit panel Click the Add a panel from the panel library option.
You will see a list of your library panels.
Filter the list or search to find the panel you want to add.
Click a panel to add it to the dashboard.
Was this page helpful?
