This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana/v8.4/panels/library-panels/delete-library-panel.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana/v8.4/panels/library-panels/delete-library-panel/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Delete a Grafana library panel
Delete a library panel when you no longer need it.
Before you begin
- Verify that the panel does not appear on a dashboard.
To delete a library panel:
Hover over Dashboard on the left menu, and select Library panels from the drop-down options.
Select a library panel that is being used in different dashboards.
You will see a list of all the dashboards.
Select the panel you want to delete.
Click the delete icon next to the library panel name.
Was this page helpful?
