This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana/v8.4/panels/library-panels/manage-library-panel.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana/v8.4/panels/library-panels/manage-library-panel/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Manage Grafana library panels
You can adjust library panel configuration at any time.
Before you begin
To view and manage a library panel:
Hover over the Dashboard option on the left menu, then click Library panels.
You can see a list of previously defined library panels.
![Screenshot of the edit panel Screenshot of the edit panel]()
Screenshot of the edit panel Search for a specific library panel if you know its name.
You can also filter the panels by folder or type.
Was this page helpful?
