This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana/v8.4/panels/library-panels/unlink-library-panel.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana/v8.4/panels/library-panels/unlink-library-panel/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Unlink a Grafana library panel
Unlink a library panel when you want to make a change to the panel and not affect other instances of the library panel.
Before you begin
- Identify the panel you want to unlink.
To unlink a library panel from a dashboard:
- Hover over Dashboard on the left menu, and then click Library panels.
- Select a library panel that is being used in different dashboards.
- Select the panel you want to unlink.
- Click the title of the panel and then click Edit. The panel opens in edit mode.
- Click the Unlink option on the top right corner of the page.
Was this page helpful?
