This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana/v8.4/panels/working-with-panels/view-json-model.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana/v8.4/panels/working-with-panels/view-json-model/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
View a panel JSON model
Explore and export panel, panel data, and data frame JSON models.
Before you begin:
To view a panel JSON model:
Open the panel inspector and then click the JSON tab or in the panel menu click Inspect > Panel JSON.
In Select source, choose one of the following options:
- Panel JSON - Displays a JSON object representing the panel.
- Panel data - Displays a JSON object representing the data that was passed to the panel.
- DataFrame structure - Displays the raw result set with transformations, field configuration, and overrides configuration applied.
You can expand or collapse portions of the JSON to explore it, or you can click Copy to clipboard and paste the JSON in another application.
Was this page helpful?
