Upgrade to Grafana v9.2
We recommend that you upgrade Grafana often to stay current with the latest fixes and enhancements. Because Grafana upgrades are backward compatible, the upgrade process is straightforward, and dashboards and graphs will not change.
In addition to common tasks you should complete for all versions of Grafana, there might be additional upgrade tasks to complete for a version.
Note: There might be minor breaking changes in some releases. We outline these changes in the What’s New document for each release.
For versions of Grafana prior to v9.2, we published additional information in the Release Notes.
When available, we list all changes with links to pull requests or issues in the Changelog.
Note: When possible, we recommend that you test the Grafana upgrade process in a test or development environment.
Back up the Grafana database
Although Grafana automatically upgrades the database on startup, we recommend that you back up your Grafana database so that you can roll back to a previous version, if required.
SQLite
If you use SQLite, you only need to back up the grafana.db file. On Unix systems, the database file is usually located in /var/lib/grafana/.
If you are unsure which database you use and where it is stored, check the Grafana configuration file. If you
installed Grafana to a custom location using a binary tar/zip, the database is usually located in <grafana_install_dir>/data.
MySQL
To back up or restore a MySQL Grafana database, run the following commands:
backup:
> mysqldump -u root -p[root_password] [grafana] > grafana_backup.sql
restore:
> mysql -u root -p grafana < grafana_backup.sqlPostgres
To back up or restore a Postgres Grafana database, run the following commands:
backup:
> pg_dump grafana > grafana_backup
restore:
> psql grafana < grafana_backupBackup plugins
We recommend that you back up installed plugins before you upgrade Grafana so that you can roll back to a previous version of Grafana, if necessary.
Upgrade Grafana
The following sections provide instructions for how to upgrade Grafana based on your installation method.
Debian
To upgrade Grafana installed from a Debian package (.deb), complete the following steps:
In your current installation of Grafana, save your custom configuration changes to a file named
<grafana_install_dir>/conf/custom.ini.This enables you to upgrade Grafana without the risk of losing your configuration changes.
Download the latest version of Grafana.
Run the following
dpkg -icommand.wget <debian package url> sudo apt-get install -y adduser sudo dpkg -i grafana_<version>_amd64.deb
APT repository
To upgrade Grafana installed from the Grafana Labs APT repository, complete the following steps:
Run the following commands:
sudo apt-get update sudo apt-get upgrade
Grafana automatically updates when you run apt-get upgrade.
Binary .tar file
To upgrade Grafana installed from the binary .tar.gz package, complete the following steps:
Download the binary
.tar.gzpackage.Extract the downloaded package and overwrite the existing files.
RPM or YUM
To upgrade Grafana installed using RPM or YUM complete the following steps:
Perform one of the following steps based on your installation.
If you downloaded an RPM package to install Grafana, then complete the steps documented in Install Grafana on Red Hat, RHEL, or Fedora or Install Grafana on SUSE or openSUSE to upgrade Grafana.
If you used the Grafana YUM repository, run the following command:
sudo yum update grafanaIf you installed Grafana on openSUSE or SUSE, run the following command:
sudo zypper update
Docker
To upgrade Grafana running in a Docker container, complete the following steps:
Run a commands similar to the following commands.
Note: This is an example. The parameters you enter depend on how you configured your Grafana container.
docker pull grafana/grafana docker stop my-grafana-container docker rm my-grafana-container docker run -d --name=my-grafana-container --restart=always -v /var/lib/grafana:/var/lib/grafana grafana/grafana
Windows
To upgrade Grafana installed on Windows, complete the following steps:
Download the Windows binary package.
Extract the contents of the package to the location in which you installed Grafana.
You can overwrite existing files and folders, when prompted.
Mac
To upgrade Grafana installed on Mac, complete the following steps:
Download the Mac binary package.
Update Grafana plugins
After you upgrade Grafana, we recommend that you update all plugins because a new version of Grafana can make older plugins stop working properly.
Run the following command to update plugins:
grafana-cli plugins update-allTechnical notes
Beginning in v9.2, Grafana has a supported database versions policy. As of this release, MySQL versions from 5.7, postgres versions from v10, and SQLite 3 are supported databases.
