This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/k6/v0.48.x/using-k6/scenarios/executors/externally-controlled.md, or by sending Accept: text/markdown to https://grafana.com/docs/k6/v0.48.x/using-k6/scenarios/executors/externally-controlled/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Externally controlled
Control and scale execution at runtime via k6’s REST API or the CLI.
Previously, the pause, resume, and scale CLI commands were used to globally control
k6 execution. This executor does the same job by providing a better API that can be used to
control k6 execution at runtime.
Note that, passing arguments to the scale CLI command for changing the amount of active or
maximum VUs will only affect the externally controlled executor.
Options
The externally-controlled executor has no graceful stop.
Besides that, this executor has all the common configuration options, and these particular ones:
| Option | Type | Description | Default |
| duration(required) | string | Total test duration. | - |
| vus | integer | Number of VUs to run concurrently. | - |
| maxVUs | integer | Maximum number of VUs to allow during the test run. | - |
When to use
If you want to control the number of VUs while the test is running.
Important: this is the only executor that is not supported in k6 cloud, it can only be used
locally with k6 run.
Example
In this example, we’ll execute a test controllable at runtime, starting with 10 VUs up to a maximum of 50, and a total duration of 10 minutes.
import http from 'k6/http';
export const options = {
discardResponseBodies: true,
scenarios: {
contacts: {
executor: 'externally-controlled',
vus: 10,
maxVUs: 50,
duration: '10m',
export default function () {
http.get('https://test.k6.io/contacts.php');
}Once the test has started, it can be externally controlled with the pause, resume, and scale CLI commands.
Was this page helpful?
