This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/k6/v0.52.x/using-k6/k6-options.md, or by sending Accept: text/markdown to https://grafana.com/docs/k6/v0.52.x/using-k6/k6-options/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Options
Options configure test-run behavior. For example, options are how you define test tags, thresholds, user agents, and the number of virtual users and iterations.
| On this page | Read about… |
| How to use options | How to set options in different places (with examples), how to override options, and how to access the value of an option as the test runs. |
| Options reference | Every option, with examples, defaults, and descriptions. |
Was this page helpful?
