This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/k6/v0.52.x/using-k6/test-authoring/test-builder.md, or by sending Accept: text/markdown to https://grafana.com/docs/k6/v0.52.x/using-k6/test-authoring/test-builder/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Test builder
The k6 Test Builder provides a graphical interface to generate a k6 test script based on your input. Then, you can copy the test script and run the test from the CLI.
Though we strongly believe that scriptable, code-based tools will help you get the most out of your performance-testing efforts, a GUI-based tool like the test builder could help you:
- Speed up the test creation.
- Learn the k6 API quickly.
- Collaborate with non-coders to build tests.
The k6 Test Builder is free to use and is available in:
Was this page helpful?
