About Grafana Mimir anonymous usage statistics reporting
Grafana Mimir includes a system that optionally and anonymously reports non-sensitive, non-personally identifiable information about the running Mimir cluster to a remote statistics server. Mimir maintainers use this anonymous information to learn more about how the open source community runs Mimir and what the Mimir team should focus on when working on the next features and documentation improvements.
The anonymous usage statistics reporting is disabled by default. If you agree to anonymous collection of usage statistics, you can enable this feature.
The statistics server
When usage statistics reporting is enabled, information is collected by a server that Grafana Labs runs. Statistics are collected at https://stats.grafana.org.
Which information is collected
When the usage statistics reporting is enabled, Grafana Mimir collects the following information:
- Information about the Mimir cluster and version:
- A unique, randomly-generated Mimir cluster identifier, such as
3749b5e2-b727-4107-95ae-172abac27496. - The timestamp when the anonymous usage statistics reporting was enabled for the first time, and the cluster identifier was created.
- The Mimir version, such as
2.3.0. - The Mimir branch, revision, and Golang version that was used to build the binary.
- Information about the environment where Mimir is running:
- The operating system, such as
linux. - The architecture, such as
amd64. - The Mimir memory utilization and number of goroutines.
- The number of logical CPU cores available to the Mimir process.
- Information about the Mimir configuration:
- The
-targetparameter value, such asallwhen running Mimir in monolithic mode. - The
-blocks-storage.backendvalue, such ass3. - The
-ingester.ring.replication-factorvalue, such as3.
- The
- Information about the Mimir cluster scale:
- Ingester:
- The number of in-memory series.
- The number of tenants that have in-memory series.
- The number of samples and exemplars ingested.
- Querier, where no information is tracked about the actual request or query:
- The number of requests to queriers that are split by API endpoint type:
- Remote read.
- Instant query.
- Range query.
- Exemplars query.
- Labels query.
- Series query.
- Metadata query.
- Cardinality analysis query.
- Ingester:
Note: Mimir maintainers commit to keeping the list of tracked information updated over time, and reporting any change both via the CHANGELOG and the release notes.
Enable the anonymous usage statistics reporting
If you would like to participate in usage statistics reporting, set the CLI flag -usage-stats.enabled=true or change the following YAML configuration:
usage_stats:
enabled: true
