Configuring Grafana Mimir hash rings
Hash rings are a distributed consistent hashing scheme and are widely used by Grafana Mimir for sharding and replication.
Each of the following Grafana Mimir components builds an independent hash ring. The CLI flags used to configure the hash ring of each component have the following prefixes:
- Ingesters:
-ingester.ring.* - Distributors:
-distributor.ring.* - Compactors:
-compactor.ring.* - Store-gateways:
-store-gateway.sharding-ring.* - (Optional) Query-schedulers:
-query-scheduler.ring.* - (Optional) Rulers:
-ruler.ring.* - (Optional) Alertmanagers:
-alertmanager.sharding-ring.*
The rest of the documentation refers to these prefixes as <prefix>.
You can configure each parameter either via the CLI flag or its respective YAML config option.
Configuring the key-value store
Hash ring data structures need to be shared between Grafana Mimir instances. To propagate changes to the hash ring, Grafana Mimir uses a key-value store. The key-value store is required and can be configured independently for the hash rings of different components.
Grafana Mimir supports the following key-value (KV) store backends for hash rings:
memberlist(default)consuletcdmulti
You can configure the KV store backend setting the <prefix>.store CLI flag (for example, -ingester.ring.store).
Memberlist (default)
By default, Grafana Mimir uses memberlist as the KV store backend.
At startup, a Grafana Mimir instance connects to other Mimir replicas to join the cluster.
A Grafana Mimir instance discovers the other replicas to join by resolving the addresses configured in -memberlist.join.
The -memberlist.join CLI flag must resolve to other replicas in the cluster and can be specified multiple times.
The -memberlist.join can be set to:
- An address in the
<ip>:<port>format. - An address in the
<hostname>:<port>format. - An address in the DNS service discovery format.
The default port is 7946.
Note: At a minimum, configure one or more addresses that resolve to a consistent subset of replicas (for example, all the ingesters).
Note: If you’re running Grafana Mimir in Kubernetes, define a headless Kubernetes Service which resolves to the IP addresses of all Grafana Mimir pods. Then you set
-memberlist.jointodnssrv+<service name>.<namespace>.svc.cluster.local:<port>.
Note: The
memberlistbackend is configured globally and can’t be customized on a per-component basis. Becausememberlistis configured globally, thememberlistbackend differs from other supported backends, such as Consul or etcd.
Grafana Mimir supports TLS for memberlist connections between its components. For more information about TLS configuration, refer to secure communications with TLS.
To see all supported configuration parameters, refer to memberlist.
Configuring the memberlist address and port
By default, Grafana Mimir memberlist protocol listens on address 0.0.0.0 and port 7946.
If you run multiple Mimir processes on the same node or the port 7946 is not available, you can change the bind and advertise port by setting the following parameters:
-memberlist.bind-addr: IP address to listen on the local machine.-memberlist.bind-port: Port to listen on the local machine.-memberlist.advertise-addr: IP address to advertise to other Mimir replicas. The other replicas will connect to this IP to talk to the instance.-memberlist.advertise-port: Port to advertise to other Mimir replicas. The other replicas will connect to this port to talk to the instance.
Cluster label verification
By default, a Grafana Mimir memberlist joins a cluster with any instance that is discovered when hosts are resolved, based on the -memberlist.join CLI flag setting or the memberlist’s YAML configuration option.
If, for any reason, the discovered addresses include instances of other Grafana Mimir clusters, or instances of other distributed systems that use a memberlist, Grafana Mimir joins these unrelated clusters together.
To avoid this, Grafana Mimir provides an additional type of validation known as cluster label verification.
When cluster label verification is enabled, all memberlist internal traffic is prefixed with the configured cluster label. Any traffic that does not match that prefix is discarded, to ensure that only the replicas that have the same configured label can connect to each other.
Migrate to using cluster label verification
Migrate a Grafana Mimir cluster to use cluster label verification:
- Disable cluster label verification on all cluster instances via the
-memberlist.cluster-label-verification-disabled=trueCLI flag (or its respective YAML configuration option). - Wait until the configuration change has been rolled out to all Grafana Mimir instances.
- On each cluster, define a label that is unique to that cluster and the same on all instances via the
-memberlist.cluster-labelCLI flag (or its respective YAML configuration option). This label must be the same on all instances that are part of the same cluster. For example, if you run a Grafana Mimir cluster in a dedicated namespace, then set the cluster label to the name of the namespace. - Wait until the configuration change has been rolled out to all Grafana Mimir instances.
- Enable cluster label verification on all clusters instances by removing the configuration option
-memberlist.cluster-label-verification-disabled=true. - Wait until the configuration change has been rolled out to all Grafana Mimir instances.
Fine tuning memberlist changes propagation latency
The cortex_ring_oldest_member_timestamp metric can be used to measure the propagation of hash ring changes.
This metric tracks the oldest heartbeat timestamp across all instances in the ring.
You can execute the following query to measure the age of the oldest heartbeat timestamp in the ring:
max(time() - cortex_ring_oldest_member_timestamp{state="ACTIVE"})The measured age shouldn’t be higher than the configured <prefix>.heartbeat-period plus a reasonable delta (for example, 15 seconds).
If you experience a higher changes propagation latency, you can adjust the following settings:
- Decrease
-memberlist.gossip-interval - Increase
-memberlist.gossip-nodes - Decrease
-memberlist.pullpush-interval - Increase
-memberlist.retransmit-factor
Consul
To use Consul as a backend KV store, set the following parameters:
<prefix>.consul.hostname: Consul hostname and port separated by colon. For example,consul:8500.<prefix>.consul.acl-token: ACL token used to authenticate to Consul. If Consul authentication is disabled, you can leave the token empty.
To see all supported configuration parameters, refer consul.
Etcd
To use etcd as a backend KV store, set the following parameters:
<prefix>.etcd.endpoints: etcd hostname and port separated by a colon. For example,etcd:2379.<prefix>.etcd.username: Username used to authenticate to etcd. If etcd authentication is disabled, you can leave the username empty.<prefix>.etcd.password: Password used to authenticate to etcd. If etcd authentication is disabled, you can leave the password empty.
Grafana Mimir supports TLS between its components and etcd. For more information about TLS configuration, refer to secure communications with TLS.
To see all supported configuration parameters, refer to etcd.
Multi
The multi backend is an implementation that you should use only for migrating between two other backends.
The multi backend uses two different KV stores: the primary and the secondary.
The primary backend receives all reads and writes.
The secondary backend only receives writes.
The primary and secondary backends can be swapped in real-time, which enables you to switch from one backend to another with no downtime.
You can use the following parameters to configure the multi KV store settings:
<prefix>.multi.primary: The type of primary backend store.<prefix>.multi.secondary: The type of the secondary backend store.<prefix>.multi.mirror-enabled: Whether mirroring of writes to the secondary backend store is enabled.<prefix>.multi.mirror-timeout: The maximum time allowed to mirror a change to the secondary backend store.
Note: Grafana Mimir does not log an error if it is unable to mirror writes to the secondary backend store. The total number of errors is only tracked through the metric
cortex_multikv_mirror_write_errors_total.
The multi KV primary backend and mirroring can also be configured in the runtime configuration file. Changes to a multi KV Store in the runtime configuration apply to all components using a multi KV store.
The following example shows a runtime configuration file for the multi KV store:
multi_kv_config:
# The runtime configuration only allows to override the primary backend and whether mirroring is enabled.
primary: consul
mirror_enabled: trueNote: The runtime configuration settings take precedence over CLI flags.
Ingester migration example
The following steps show how to migrate ingesters from Consul to etcd:
- Configure
-ingester.ring.store=multi,-ingester.ring.multi.primary=consul,-ingester.ring.multi.secondary=etcd, and-ingester.ring.multi.mirror-enabled=true. Configure both Consul settings-ingester.ring.consul.*and etcd settings-ingester.ring.etcd.*. - Apply changes to your Grafana Mimir cluster. After changes have rolled out, Grafana Mimir uses Consul as primary KV store, and all writes are mirrored to etcd too.
- Configure
primary: etcdin themulti_kv_configblock of the runtime configuration file. Changes in the runtime configuration file are reloaded live, without the need to restart the process. - Wait until all Mimir instances have reloaded the updated configuration.
- Configure
mirror_enabled: falsein themulti_kv_configblock of the runtime configuration file. - Wait until all Mimir instances have reloaded the updated configuration.
- Configure
-ingester.ring.store=etcdand remove both the multi and Consul configuration because they are no longer required. - Apply changes to your Grafana Mimir cluster. After changes have rolled out, Grafana Mimir only uses etcd.
