Caution
As of 2026-03-24, the Grafana OnCall OSS project is archived. The grafana/oncall repository is read-only, and active development continues in Grafana Cloud IRM. For a fully supported and actively maintained alternative, Grafana Cloud IRM offers a modern approach to incident response and on-call management.
Insight Logs and Metrics
Metrics
Grafana OnCall Metrics represents certain parameters, such as:
- A total count of alert groups for each integration in every state (firing, acknowledged, resolved, silenced).
It is a gauge, and its name has the suffix
alert_groups_total - Response time on alert groups for each integration (mean time between the start and first action of all alert groups
for the last 7 days in selected period). It is a histogram, and its name has the suffix
alert_groups_response_timewith the histogram suffixes such as_bucket,_sumand_count
You can find more information about metrics types in the Prometheus documentation.
To retrieve Prometheus metrics use PromQL. If you are not familiar with PromQL, check this documentation.
For Grafana Cloud customers
OnCall application metrics are collected in preinstalled grafanacloud_usage datasource and are available for every
cloud instance.
Metrics have prefix grafanacloud_oncall_instance, e.g. grafanacloud_oncall_instance_alert_groups_total and
grafanacloud_oncall_instance_alert_groups_response_time_seconds_bucket.
For open source customers
To collect OnCall application metrics you need to set up Prometheus and add it to your Grafana instance as a datasource. You can find more information about Prometheus setup in the OSS documentation
Metrics will have the prefix oncall, e.g. oncall_alert_groups_total and oncall_alert_groups_response_time_seconds_bucket.
Your metrics may also have additional labels, such as pod, instance, container, depending on your Prometheus setup.
Metric Alert groups total
This metric has the following labels:
Query example:
Get the number of alert groups in “firing” state in integration “Grafana Alerting” in Grafana stack “test_stack”:
grafanacloud_oncall_instance_alert_groups_total{slug="test_stack", integration="Grafana Alerting", state="firing"}Metric Alert groups response time
Query example:
Get the number of alert groups with response time more than 10 minutes (600 seconds) in integration “Grafana Alerting” in Grafana stack “test_stack”:
grafanacloud_oncall_instance_alert_groups_response_time_seconds_bucket{slug="test_stack", integration="Grafana Alerting", le="600"}Dashboard
To import OnCall metrics dashboard go to Administration -> Plugins page, find OnCall in the plugins list, open
Dashboards tab at the OnCall plugin settings page and click “Import” near “OnCall metrics”. After that you can find
the “OnCall metrics” dashboard in your dashboards list. In the datasource dropdown select your Prometheus datasource
(for Cloud customers it’s grafanacloud_usage). You can filter data by your Grafana instances, teams and integrations.
To update the dashboard to the newest version go to Dashboards tab at the OnCall plugin settings page and click
“Re-import”.
Be aware: if you have made changes to the dashboard, they will be deleted after re-importing. To save your changes go
to the dashboard settings, click “Save as” and save a copy of the dashboard.
Insight Logs
Note: Grafana OnCall insight logs are available in Grafana Cloud only. We’re in the process of rolling out Insight Logs to all customers, if you don’t see insight logs in your Grafana Cloud stack, please reach out to support.
Grafana OnCall Insights Logs represents certain activities, such as when:
- A user creates, updates, or deletes a resource.
- A Maintenance mode is started or finished for an integration.
- A user configures a ChatOps integration.
This configuration is done for you in Grafana Cloud with Usage Insights Loki data source. You can use this query to retrieve all logs related to your OnCall instance.
{instance_type="oncall"} | logfmt | __error__=``Resource insight logs
Logs are created each time a user modifies any resource in Grafana OnCall.
These logs will have action_type=resource field and can be retrieved with following query:
{instance_type="oncall"} | logfmt | __error__=`` | action_type = `resource`Format
Logs contain the following fields, where the fields followed by * are always available, and the others depend on the logged event:
resource types are: integration_heartbeat, escalation_chain, integration, outgoing_webhook,
escalation_policy, public_api_token, schedule_export_token,user_schedule_export_token,
oncall_shift, web_schedule, ical_schedule, calendar_schedule, organization, user, webhook.
Maintenance insight logs
Logs are created every time when a maintenance mode is started or finished for an integration.
These logs will have action_type=maintenace field and can be retrieved with following query:
{instance_type="oncall"} | logfmt | __error__=`` | action_type = `maintenance`Format
Logs of maintenance insights contain the following fields, where the fields followed by * are always available, and the others depend on the logged event:
ChatOps insight logs
Logs are created when user modifies ChatOps settings.
These log lines will have action_type=chat_ops field and can be retrieved with following query:
{instance_type="oncall"} | logfmt | __error__=`` | action_type = `chat_ops`Format
Logs of chatops insight logs contain the following fields, where the fields followed by * are always available, and the others depend on the logged event:
chatops action names: workspace_connected, workspace_disconnected, channel_connected, channel_disconnected, user_linked, used_unlinked, default_channel_changed.
Examples
Here is some examples of practical queries to Grafana OnCall insight logs. LogQL is used to retrieve them. If you are not familiar with LogQL check this documentation.
Resource IDs are used a lot in insight logs. You can find them in web ui (example for integration):
- Open Grafana OnCall.
- Navigate to resource.
- The URL looks like
https://<YOUR_STACK_SLUG>/a/grafana-oncall-app/integrations/C5VXMIFKKP67K. - Integration ID is
C5VXMIFKKP67K.
Alternatively you can find resource ID using public API or browser dev tools.
Actions performed by user:
{instance_type="oncall"} | logfmt | __error__=`` | action_type = `resource` and author="<username>"Actions performed with all schedules:
{instance_type="oncall"} | logfmt | __error__=`` | action_type = `resource` and (resource_type=`web_schedule` or resource_type=`calendar_schedule` or resource_type=`ical_schedule`)Changes of escalation policies for escalation chain:
{instance_type="oncall"} | logfmt | __error__=`` | action_type = `resource` and resource_type=`escalation_policy` and escalation_chain_id=`<ESCALATION_CHAIN_ID>`Maintenance events for integration:
{instance_type="oncall"} | logfmt | __error__=`` | action_type = `maintenance` and resource_id=`CSA67IQW2NMVL`Actions performed with slack chatops integration:
{instance_type="oncall"} | logfmt | __error__=`` | action_type = `chat_ops` and chat_ops_type=`slack`
